Hey guys, I’ve got the code F1 D05 witch is the vehicle down sensor, although there is nothing wrong with my vehicle down sensor, my issue is a misfire. The ecu, rectifier, coils, leads, plugs, are all in perfect working order everything has been swapped from one ski to another the exact same and tested perfect, injectors seem to be spraying the same, also fuel pump had been swapped and tested fine.
