I have run about 40 to 50 gals. of gas with pennzoil tcw3 blend not knowing it required api-tc. Bought seadoo use and am fairly sure previous owner used a BRP oil but do not know which.
Question, can i siphon the majority out of the oil tank reservior and add what you would reccomend?
Question, do i need to drain the lines,oil tank, rotary chamber,injection pump and bleed?
Question, what BRP oil would you reccomend?
BRP Mineral / Blend / Full Synthetic
Some have said to run mineral others say blend.
Gets confusing. Have had no problems with 717.
Changed fuel lines and filters.
How do you vacum tank and lines with shop vac.
Any info would be appreciated. The more detail the better. Thanks for your time and info.
Thanks again, Ronnie from north carolina
