21 - 30 of 30 Posts
I know im going to sound like a dumb ass but im new at the PWC's and my readout on the bars isn't working on my 1996 polaris SLT 780. how do i check the fuses? please help.
96 polaris sl900 stator problem
These checks are to be done after the initial static check of all components such as but not limited to the following:
Stator
Coils
Spark plug wires
Grounds
I hope that has helped some of you out. Below I have listed the numbers of the stator update kits for the older PVL ignitions.
Twins 96/97 2873355
Twins 97/98 2873022
Triples 96-98 2873091
Triples 99 2873356 this is for the sltx only.
8 Pin Connectors:
Triple 2460875(must use 4010170 stator) see above
Twin 2460718(must use 4010172 stator) see above
Hi you seem very sharp on these polaris watercrafts, please help me out, I bouhgt a 96 sl900 that idles well runs good up to 3500 rpms then starts missing or stuttering badly after that,while out of the water. in the water it will only run up to 40 mph the bog out. I was told there was a new stater put in 3 years ago. the ski has only 45 hrs. I checked the cdi box part no. and it matches the one that comes with the updated stator kit. I also checked the stater with an ohms test and one of the exciter coils reads 8 ohms and the spec say it should be 1250. all coils checked good. Is it possible that this newer version of the stator also went bad or what could my problem be. one dealers says that they just quit when the stator is bad another says different . please help thanks
I had the same problem on My 2002 Virage and it turned out to be the stator. Run a compression test on both cylinders. If they are within 10% of the specs, then run through the test procedure in the service manual for the stator. If both the compression test and procedure for the stator turn out to be fine, then replace the CDI box.
Other things that can be done.
1. Place fuel stabilizer in the tank
2. Check for fuel leaks between the tank and carb
3. Consider rebuilding the carb (filter might be clogged or the pulse diagram might be bad>
4. Check the impedance readings on the ignition coil
5. Check the ignition timing
crankcase (6 mm) 78 in.-lb. crankcase (8 mm) 16 ft.-lb. crankcase (10 mm) 26 ft.-lb.
Cylinder head nuts 18 ft.-lb. cylinder base 28 ft.-lb exhaust manifold 16 ft.-lb.
exhaust pipe to manifold 45 ft.-lb. carb manifold 78 in.-lb water outlet manifold 78 in.-lb.
timing on 2001 Virage.
I just got the specs on ht timing of the 2001 Virage. Thanks a Million Tech Library and for all those responsible for creating it. Now, how the heck do you change the timing with it running? I just rebuilt the engine, new crank and all, and the timing is outta whack. Any help greatly appreciated. Thanks Lou
I have a 94 Polaris SL750 and im wondering if a 96 motor will work in my jetski i heard that the stators might be different or will my brain box be ok and run right??? Thanks
please help !!!
hi, my polaris 140 broke down a year ago and cannot find anyone who can fix it! or want to fix it as they dont like polaris. i know it must be a electrical problem telling the engine it is over heating, because it used to run for a while then just stop!! does anyone know who can re wire the computer?? or where i can send it. it needs someone to take it out because so many people think they have fixed it then when u are on it for a hour it breaks down. it needs someone to have abit of time with it, i dont care how long it take.... it is currently in majorca spain and i live in the uk..... please help!!!!! :(
21 - 30 of 30 Posts
