I have a Waverunner XL 1200Ltd 2000. The throttle began sticking in the open position. When the engine is cold or in operation it works fine. About 15 minutes after shutdown, the throttle lever will not return to the closed position after opening. After complete cool down, throttle is fine again. The engine cylinder heads are just warm to the touch at shutdown. Throttle and oil pump cables remain free. Problem seems to be somewhere down stream of the wheel where the cables connect. I can close the throttle by depressing the oil pump cable but the spring is not strong enough to close it until an hour or so of cool down. Sure would appreciate any suggestions.
Derf
Derf
