Soooo, here is the deal. Ive been threw 2 1000s. well kinda three, but i bought one ended up blowing it up, bought another one and stole some parts from the first one and blew it up. then combined all the parts to make a third not so good one and that one did not last long.
So here now i want to rebuild one the right way and give it some powwwwer.
so here is what i want to do:
i have std pistons in there and want to go to the oversized 85mm pistons. but that requires alot of work but think it would be worth it, i also want to completly rebuild the carbs or maby even get bigger ones. New reeds, along with an impeller.
Now to do the oversized 85mm kit i will use wiseco pistons. I read somewhere that to do this i need to bore it out, then weld in the iner o ring slot and machine a new o ring slot farther out and machine it all flat.
Anyone know if this is needed?
Also anyone rebuilt a TS? or did a big bore kit? anything will help
