I'm new here and new to jetski's and two strokes, but I've got a pretty good automotive background, anyways I just bought a 94 tigershark 640 for basically pennies(it sat for two years). I got it home, pulled the plugs, and turned it over and a good amount of water sprayed out of the forward cylinder. The rear cylinder had no water in it at all. I checked for spark, it was good, put some fuel in it, and cleaned the plugs. I turned it over again with the plugs out and it is still spraying a little mist of water out of the front cylinder but the rear cylinder is fine. Then, I did a compression test, 150 lbs on the front cylinder, 140 on the rear. When I try and start it, I can hear one cylinder fire a few times, but it won't start. Any ideas appriciated...
