Help... This is what I have checked so far and no change in this problem. Check compression it was 125 psi, Replaced spark plugs, Clean and replaced fuel, Check timming it was 24 deg adv, Found fuel line was spilt coming from tank to pump and fix, Checked inpella and you can turn with hand, Carbs were rebuilt and new reeds were replaced. Any other suggestion that I could check.. Thanks.
