Hey guys, just purchased a Daytona 640 I think its a 1995. Anyways I tried starting it, and doing a compression test, than the starter stopped! Than I pulled the tester and other spark plug off and noticed I had a case of hydrualic lock. I cranked the engine and shot milky water out of cylinders. Than I pulled the head off and noticed on each down stroke oily milky water enters the cylinder. I inspected the pistons and cylinder walls and they are perfect!
Is there some kind of flapper valve or exhaust valve that prevents water or exhaust from entering the cylinder? Thanks in Advance!!
------>dirtyhands!
------>dirtyhands!
