This is my used Sea Doo jet ski for sale 2003 Sea Doo RXDI, mint condition with only 63 hours. Included is a trailer and ski cover.
My loss is your gain, asking only $3500!
The 2003 Sea Doo RXDI has an advanced fuel delivery technology available offered only by Sea Doo, the first manufacturer to mass-produce fuel injected watercraft and 130hp fuel efficient motor with 37% better fuel economy over carbureted models and extra large fuel tank which extends riding times and provides power and strong acceleration and an excess of top-end that will keep you in front of the pack. The award winning hull design that offers the best in predictable and precise handling, a hull that almost does what you think before you think it. Fiberglass construction provides superior strength with extra material added where needed to ensure long lasting durability.
Rated Horsepower: 130hp
Engine Type: Two-stroke, Twin-cylinder Rotax® Orbital Direct Injection, R.A.V.E™ exhaust
Bore/Stroke: 88mm x 78.2mm
Displacement: 951 cc
Fuel: Regular Unleaded
Starting: Electric
Ignition: Digital Inductive
Compression Ratio: 6.1:1
Carburetor/Injection: Electronic Fuel Injection
Impeller: Stainless Steel
Length: 112.3 in. (285 cm)
Width: 47.3 in. (120 cm)
Height: 41.0 in. (104 cm)
Dry Weight: 606 lbs. (275 Kg)
Fuel Capacity: 15.0 US gallons / 56.6 liters Reserve
Oil Capacity: 1.6 US gallons (6 liters)
Storage Capacity: 10.6 US gallons (40.3 liters)
Hull Material: Ultra-Lightweight SMC (Sheet Molded Compound)
Starting: Electric
