Hi all I've got a 2005 vx110 deluxe and recently I was out on the water when suddenly the warning light came in and started beeping with the engine sign on display but the ski was running absolutely fine, I noticed it was low voltage so ended up changing battery and my brother took it out and was apparently fine but since then I've had problems with said battery and took it back as wouldn't charge correctly. Since the last ride I've had the ski serviced with new plugs, oil and oil filter and also a brand new fully charged battery but yesterday it happened again even though the ski is running as well as it ever has and if I shut it off and wait for the display to clear it then starts and runs as if it never happened but will then do it again 🤷‍♂️.Does anyone know what this could be as ski is running sweet so find it a bit odd, sorry for such a long post and any advice would be gratefully received, cheers Lee 👍🏻
