so with all te work finally got exhaust housing and manifold off we loosened the engine bolts enuff to move engine a bit slide out exhaust attched to the turbo housing
then we removed the wastegate with a 30mm torx unpried the waste gate cap which was spinning it shouldnt have that meant the ballon type thing in there was busted we now must replace or fix it
ill post pics of wastegate in a bit can anyone help maybe we need to replace the solenoid ????/
ok ok.......we have done research and now found out you can replace wastegate actuator
but yyou must be a lil techkie were working on getting parts and will let yoyu guys know how we doing any ???? or if you want service manual hit us up!!!!!!!!!!!!!!!!!!
