Need help, sorry not a mechanic so forgive me for some of my terminalogy.
I have yamaha gpr 1200 two stroke (year 2000). I got it started after a few years of storage with not being started I had used starter fluid to help get it started. The next day I went and got new plugs figuring it would help it idle /run better. I went to start it and could not get it running. It was trying to turn over. So I went and got some starter fluid.
I took off plug (3 of them ) sprayed the cylinders it down and replaced plugs and put cords back on went to turn it over and it seized. I then took out plugs and there was water in cylinders. I had my hose connected to the factory intake for cooling with the little nozzle that comes with it. How did water get in the engine?
My only though it that is that the front end of the trailer was nose down and when water was trying to come out the rear it was back filling up the exhaust? is that possible. I took of the engine mount and the large pipe section right next to the engine and it was fill with water. What damage was done. Is it a matter of just opening everything and cleaning and letting it dry?
Regards
Robert
ps I can post pictures if necessay
Regards
Robert
