1 - 4 of 4 Posts
Hello, I have a 2014 Yamaha VX waverunner that starts fine and after about 30 minutes of running the ski to my destination it will not start again after being shut off. It takes about ten minutes of sitting and then the ski will start fine and run without problems. When the ski will not start the dash says low and the volts read 12.3 in the dash. Normal volts on the dash while driving are 14.7. I replaced the battery and still having this problem. I’m operating the ski in the ocean with chop and swell. Thanks for any input
Read Only
Check all the connecting (ground and positive). to make sure they are tight and clean. Get a volt meter and verify the standing battery voltage. Should be 12.5 +.
1 - 4 of 4 Posts
