1995 waveblaster. I would like to know what impeller i could use to increase low end and jumping. Group K has mentioned stock works good enough that changing may not be noticeable.
Mods: Riva pipe, ported cylinders and intake. Hotrods crankshaft, head shaved but found no real improvement with over 170 vs 150 compresion. and 200 helped but not worth overheating issues and expensive gas.
would like to try ewc or electronic water injestion on exhaust. does it work as advertised?
impeller size wanted for good jumping over stock info wanted.
