My waverunner starts up, and idle's fine when in water, the moment I go to wrap the throttle it bogs down/dies. I can get the RPM's up by very slowly pulling the throttle, but any quick motion to give it gas and it will bog/die. Im clueless to why this is happening. On land it will start and rev just fine and not bog at all. Any help or suggestions would be appriciated.
also:
I just took off the cat to see if it was causing a problem and saw that there was quite a bit of water sloshing around. Is that normal in a waverunner?
also:
