i have a 03 Gp1300r. The wear ring is bad. There are a couple aftermarkey companys that make a replaceable wear ring set up for this ski. Has anyone evertried one? If so how do you like them. The yamaha wear ring is 310 dollars and the r&d set up is 125. I kno seadoo uses a replaceable wear ring but just never heard of anyone doing it on a yamaha. Please respond!! THANKS!!
I know a lot of guys that don't like the plastic rings, since they are easily damaged and even a small rock can ruin them and result in cavitation until it is replaced. Talk to some of the Seadoo guys. The OEM ring is more expensive, but will take a lot of abuse. You will probably have to replace several of the plastic inserts over time, so it may not be that much of a difference in cost in the long run. Some of it depends on where you ride (shallow areas with sand and rocks that get picked up easily, etc..)
