I have a '99 sxi pro with the older Worx grate and plate with 0 degree bars.
The Worx parts had gave superb results but you still had to keep your weight way forward and use a ton of body english to get it smooth. The zero degree bars helped a bit. I would speculate that the 1 inch shorter pole and/or cheaper 1 inch shorter steering plate would make a huge difference.
I just bought a Valiant Blue '08 SXR 800 (it looks like the original '86 and '06 anniversary Suzuki GSX-R 750) I have these bikes and am a Suzuki fan though cool, I admit the ski does look like a suzuki GSX-R rip-off (even the name)!!!
I noticed the stock '08 does not porpise (they fixed that trait but left all the other bad ones intact plus added one to make it slow down faster off the throttle) and this ski needs your weight as far BACK as possible. It would be easier to learn to ride if I had never ridden the sxi pro.
Some parts are compatible with both models but I think I am going to keep the original WORX parts on the sxi pro and sell it. I'll order the newest WORX design for the SXR (buying today). These will be the WORX WR311 plate, WR225 grate, and WR528 sponsons.
If you are mostly in the ocean you may want to consider stainless or carbon fiber plates and grates. I have not tried any of them.
Check these sites:
blowsion.com
https://www.worxusa.com
Hope this helps and I'll let you know how these parts work.
