OK, can somebody help me out here?
I have a 1998 Yamaha Wave Venture 700.
Compression: 140psi in both cylinders
Carbs: Rebuilt good. I know how to rebuild carbs and they're done right.
Spark: Wierd
Using a timing light, one cylinder sparks normally, like clockwork. The other is sporadic. Ski runs great in the driveway, but on the water it idle's rough, runs good with a small amount of throttle, bogs down when I open up the throttle. After running with the throttle open then pulling off the seat, there seemed to be a lot of exhaust in the engine compartment.
I'm just wierded out by this one, I'm guessing that I have a bad spark plug wire, but does that explain everything?
Please help. Thanks.
Spark: Wierd
