Stabilize fuel. Change oil and filter. Fog cylinders by removing spark plugs and using 1 ounce per cylinder. Blow out water from cooling system, put marine antifreeze through if you want to. Spray all metal parts down with a silicone corrosion protector. Unhook battery, charge if you keep it warm.
