I recently bought a 98' XL 1200 with 150 hrs on it. I already had to fix the exhaust because it was filling the hull up with smoke. It never got top end speed which i was told is around 50-60 mph i only go about 30-40 maybe. I was told it could be the carbs so I put a fuel cleaner in the fuel tank it seemed to work, but the rpm's will not go above 6000, when i know it should go to at least 7. So i know there there is a problem somewhere.
I ran a compression test and from the test results it seemed normal. (from the stern to the bow: 120, 105, 102 psi)
I also am looking into getting a new impeller, I know nothing about the angles and which one to go to do, I have alrady taken it off now i just need to know which one to buy that can give me top end and good acceleration.
Please any and all help is needed, thanks again for looking
