Hey guys new to the forum, have a question for you.
I just bought a 98 XP limited, put it in the water last night and it sank!
We found out there's a big crack in the plastic exhaust elbow as it exits the ski. So instead if holding the water at the 90 degree bend it just took on water and sank. We got it back on shore drained the water, pulled the plugs, turned the engine over got the water out. Worked at it for a bit but got it running then changed out the plugs for new ones. When I got it home, fogged the cylinders out well, turned the engine over a couple times then reinstalled plugs and it fired up and seems to idle and run fine.
The part won't be here till Friday or Monday, will it be ok till I can fix it and get out on the water and run it? Anyhing else you guys would recommend to do?
Thanks in advance for the help!
