1 - 20 of 30 Posts
Hello everyone!
Just finished my first engine rebuild on my 2001 SUV 1200 that I got for free with an almost blown motor. Actually went quite well. Finally blew about five weeks back, just finished rebuilding it last Thursday. Aside from engine I also rebuilt the carb although the parts I chose probably wasn't my best choice. It was $94 and the seller was 100% feedback on ebay. I would post a link but cant. I only found out that OEM kits are best just recently.
About carburetor: Mikuni SBN series.
At first it would never start, unless I dripped fuel down carb neck. Then after correcting the mistake I made, engine was receiving way to much oil premix (guide says 3oZ per gallon, but that seems like a lot and I didn't rebuild my crank so shouldn't really need premix), after draining gas and adding fresh non premix engine ran decent (more details below). Took carbs out and realized two things 1) One needle was missing the clip that goes around lift arm and 2) accidentally did pop off pressure according to lift arm color. (oops). The current carburetor config is using all stock jets, seat is 1.2 (probably my first issue eh?), H and L screws set to stock, and the correct pop off pressure it set at 47 psi.
About Engine:
The new rebuilt top-end has a 1.5 overbore (adjusting carb H and L screws didn't really fix issue), has new head as well as gaskets. M cylinder (front) has 100 psi, C has 98, and PTO has 100, seems pretty damn healthy to me :tango_face_grin: Reeds are in good condition still, no light passing through and they snap back into place instantly.
Issue im facing more in depth:
Okay, so the jet ski idles great in and out of water. When out of water I can rev it pretty high, but am afraid of going full tilt with no cooling. When in the water I can build a tiny amount of speed around 10mph then anymore throttle and it drops RPM and cant rev past 2/8 throttle. When I had the premix in I tried my best to tune the high and low of carb with no success and when the time came to put new fuel in with no oil it was getting dark, and didn't have time to tune. Still, it struggled to accelerate. Looking at my spark plugs they seem to signify good engine operation. So yes, it still could need just a little tuning especially because of overbore, but I would appreciate any other ideas evolving around this issue. This is my first ever carbureted two stroke engine that ive owned and worked on so I'm a little lost. I guess while I wait for the next weekend to go to the lake I'd like to hear what y'all have to say. Thanks!
Read Only
Several mistakes.
Premix is not just for the crank on a new engine. Premix the first tank to achieve a TOTAL mix of 32:1, not 32:1 in the tank. Figure the system runs 50:1, so the difference is what you add to the tank. Around 1.5oz per gallon. If you added 3 per gallon, that's closer to 25:1. If you had the oil injection system apart, you would mix about a half tank at 32:1 on a new engine or 50:1 on a engine with more than 10 hours on it until the injection lines (pump to carbs) are bled.
Use the manual to set the oil pump cable.
Put the old springs back in the carbs and check pop off. Dave might have some good pop off number for that engine. Never use new springs unless they are true mikuni kits. Some after market kits are ok to use for just the gaskets, diaphragms, and seals, some shouldn't be used at all.
Compression should be closer to 120 on a fresh bore, but they are within a couple of psi of each other.
High speed screw has now relevance to anything other than 3/4-full throttle.
Low speed screw is used to set the highest smooth idle ONLY. That's all it it's used for. Idle quality, not idle speed. If it is set right, and pop off is right, starting, idle quality, and off idle acceleration will be good and crisp.
1.2 needle and seat was oem for alot.
You need to check for spark. Last plug looks like it's not firing at all, or dangerously lean.
Wow! I really did mess up quite a bit. Rookie mistakes I guess. I feel like quitting at this point and just selling it as is and someone can figure it out. Sorry, at this point I have lost a lot of confidence because to me, it should be perfect after all the time I put in to it. Unfortunately I know no PWC mechanics, only car guys. Obviously they don't know everything and may not be completely knowledgeable on these things. I can do just about anything with my Yamaha Raptor, but for some reason this is like rocket science to me. lol
Enough about me, I'll try to follow everything you said starting with a Mikuni rebuild kit (old springs gone) and see where I'll go from there. I know I'm close, and regarding the low speed screw, machine idles, and starts great. About the compression, is this only affected by head gasket and piston rings? It's on good but I feel like the gasket on lower part of cylinder may not be perfect, RTV as recommended by SBT was starting to dry when I finally got cylinder walls on.
Discussion Starter #4
Ok, so I have changed my mind a bit. As I have previously mentioned compression is about 20 psi low, thanks for that notice rod! Im gonna start by replacing head gasket again, because I think I didn't let the spray sealer sit long enough, unlike RTV it's supposed to dry before applying gaskets, was still just a little tacky. If that doesn't do the trick and comp is still low I will then move on to my cylinder base gasket, and practically rebuild the engine again without replacing pistons obviously. Ugh it's gonna be winter by the time I'm done. I noticed that earlier today I had sort of a fit, I'm much better now lol.
Read Only
Don't worry about it and just ride it. If you used wsm pistons, that could be the issue, or could be the base gasket was to thick. Just work on the carbs, get it running, and leave the other stuff for winter.
I don't use rtv on the base gaskets. If anything, use permatex high tack gasket. available at most parts stores.
https://www.summitracing.com/parts/ptx-80062?seid=srese1&gclid=Cj0KCQjwiILsBRCGARIsAHKQWLMkbbVMd-4HNsmP1xxmdqA8QrNtlHBhoT1o9ZEp7vd2WCiv4fW5wpkaAr-6EALw_wcB
If you set the mixture screws to factory specs, they should be very, very close. Make sure the regulator diaphragm is in correctly. The metal disk with holes faces the needle. The mikuni kits should come with new arms. I don't usually recommend using them, but in your case, do, and check pop off and arm height to what the manual states. Also, since your new to this, I would turn the low speed screws out a additional 1/8 turn to make them a tad richer.
Look in the general how to forums for carb stuff. There is a mikuni tuning manual there. I suggest you read it. It will give you some in site to how these carbs works, and what does what, and when, but use the carb settings in the repair manual for your ski, not the mikuni manual.
Morning guy's,
Unfortunately I don't have any factory pop off info on the 1200. The 800 is around 75/80 psi. But I'm not sure what the 1200 is. There the same carb so I'd assume they'd be the same.
Discussion Starter #7
Thanks Dave and Rod! Using SBT pistons. I believe the pop off is 47, but im not positive. Found a little datasheet on google. Even the service manual doesn't state that. I'll give the carbs another look, after putting in the new head gasket properly and trying without a spray or RTV I now get 114-118 psi compression. Thats a bit more exciting for me. Gonna do another premix tank of gas with 1.5OZ instead and continue after that to 0.5OZ all the time in case my oil pump ever goes bad. Also managed to put that in spec, it was only about a 1/16 off though. I'll update y'all on what happens, gonna put er back together and see what I do from there. Everything else but carbs seems perfect because I literally inspected almost everything, I'm almost positive. One of my guys however said replace fuel lines, can that actually help because they seem to be fine from what I can see.
Thanks!
Discussion Starter #8
Woah!!!! It revved real high, had to kill engine before it hit rev limit. Seems like the gasket could be part of the problem. Time to screw around with L screw to make idle better, i think...
"I believe the pop off is 47, but im not positive. Found a little datasheet on google"
Ya that's why I say I'm not sure on 1200 pop off.
Reving up on its own sounds like vacuum leak.
Fuel line should be ok. Yamaha used a very high quality rubber line. My 01 & 02 gpr still have original fuel lines. That is if it's still the original blue,green, gray colored stuff.
Discussion Starter #11
Yeah I thought my friends hosing suggestion was a bit false. Wish there was one sure answer but it just makes no sense to me that its not listed anywhere. I'll look for that vacuum next or the related. Feel like im so close and I have this badass relic of yamaha motors in my hands. This guy told me I should put it in a museum lol.
You'll get it. Just take your time and be patient. I have an 01 & 02 gpr. Both got torn down and gone over and are a blast to ride.
Read Only
Patience Danielson. Lol
Try setting the mixture screws to spec and turn the idle screw out until the butterflies are all the way closed and try and start it. If there is a vaccum leak it should start. If it doesnt, turn the idle screw about 1 1/2 turns once it contacts the arm and start it. If it idles high, back it off some. Its possible the idle is set to high to compensate for the mixture screws or pop off being set wrong.
Discussion Starter #14
Sounds awesome! Love working on old machines, you save so much money and you get to learn. Everything I own (except snowmobile) is used and has had some big issue which gave it a big discount and of course I've fixed it and made it like new. I most likely will never buy something new, I just don't like the way things are built these days.
Discussion Starter #15 (Edited)
Yay!
Genius! Didn't start with idle all the way off, and a nice smooth idle once screwed in 1 1/2. Most likely forgot to reset idle screw after I attempted tuning on water. I guess now it's time to put er back on the water and see what I get with new gasket. Ill update y'all on saturday most likely. Y'all might disagree with me, and probably for good reason but after my years of experience working on engines, typically electrical and clutching, I have learned to stay away from gasket sealers and RTV. Now of course if I was too cheap to replace a beat up block that has nics on gasket surface then maybe I would use it, after all the times I've used it I leak oil and now compression. I'm not positive I found the solution but I'm keeping my fingers crossed. Wish my sorry a** good luck. lmao
Edit: Finally reading that guide too, might have to take carbs out one more time, having a hard time telling difference between dull silver and shiny silver.
Read Only
If anything, your pop off is low, so it shouldn't be a big deal if it runs good. Glad you got it. Remember, your idle should be around 1100.
Discussion Starter #17
Thanks! Made my own pop off tester but I’m not so sure of it’s accuracy. Just bought a Mikuni one. I believe my springs are “dull silver” so I’ll try that first and see what I get. And I would definitely agree that it’s too low, heard these Yamahas need higher pressure. Or they’re just tuned that way.
I rarely use rtv. If it's a paper gasket like the jug base, or carb. gasket I rub brg grease into it. it softens it to get a good seal and makes it come off real easy the next time. That's old school trick. Lol. now I'm showing my age, hehe.
Also the grease will stick it in place on vertical location.
Read Only
They were running it high because of epa standards. I have seen where folks are running pop off on the 1200's in the range you have with no issues. If it's starting easy hot or cold, idles good, off idle acceleration is good, not running rich up to 1/4 throttle, I would leave it.
Discussion Starter #20
Thanks! I really like that idea and will totally try it out next time!
1 - 20 of 30 Posts
