Hi I have a 2000 1200 xl power valve limited. I have torn it down somewhat and now see the oil line came off causing my 3rd piston to basically burn-up, the rings have broken off and are basically fused to the piston. Anywhoo I can see the oil line that came off after taking out the exhaust plain as day. ( which I will mix after this) I am wondering, can and if so how much can I hone this plated cylinder. The cylider is not horrrible but you can feel scar marks on it. Should I get a new /used cyinder,bore, sleeve? the other two are pretty good but still only had just over 100 psi per, maybe just clean those up and new pistons and rings. Was running about 62 then started missing and that was that. Thanks for any help
newbie but learning fast.
