1 - 6 of 6 Posts
Good day,
I accidently reversed the battery cables on our 2015 V1 jet ski.
I have corrected the problem, charged the battery.
Jet ski shows no power.
Is there a fuse I can replace or did I do more damage then a blown fuse?
Any help or suggestion will be greatly appreciated.
Ron
I did the same cost me the whole electric box they have a small fuse but it goes past fuse in my case
Discussion Starter #4
I was finally able to get to the jet ski and remove the fuse panel cover. It looks like the first fuse I pulled out is blown (30 amp). I plan to go the shop to purchase some replacement fuses.
Can someone tell me what style the fuses are? They are not the same size of the spare fuses I have for my cars.
Thanks ahead of time.
Discussion Starter #6
Thank you. Turns out the fuse is a MINI fuse. I plan to install the replacement in the next couple of days. I will let you know if this fixes my problem.
1 - 6 of 6 Posts
