The "W" has the additives for water use. Probably not a big deal for a 2000, but would void your warranty on a newer machine to use the non-water rated oil.
Use 2W as the 2 M is for outboard motors. Plus I'm pretty sure your watercraft has a catalytic converter and 2W is a pwc oil that is specially formulated for watercraft with cats.
2M 2-Stroke Engine Oil Semi-Synthetic Injector Oil for Outboard Motors. Naturally, any outboard oil should be TCW-3 approved. Yamalube oils are so good they have actually been used as the test oil for many of the TC-W3 ratings! That means that all other TCW-3 oils had to measure up to our high standards. Given that, we raised the bar again with Yamalube 2-M - the new standard for outboard oils. Features Extreme Performance Formula. An exclusive additive blend works to guard against power robbing ring stick, and carbon build up, while special additives minimize wear. This oil has been designed for the most grueling conditions your outboard faces. Whether its extended full-throttle operation, or engine punishing & out of the hold acceleration, or even hour after hour of trolling, this oil stands up to the test. With this kind of extreme performance ability, Yamalube 2-M offers the best everyday protection too. Rust and Corrosion Protection This oil is formulated with the best rust and corrosion protection we could find. Formulated especially for outboard motors. Not recommended for WaveRunner or Sport Boats.
