Dear Fans,
I'm fixing a '96 Yamaha Wave Raider 700 (2 cylinders, 1 carb.). I cannot find exact description of the cooling line.
So my problem:
I connected the jet to the garden hose, the engine works fine. I realized the water does not go to the head through the T pipe, it goes out through the side őisser on the hull.
-->Is this the propper assembly, see attached files (I am not sure)?
(I found some versions without this T pipe.)
I really would like to avoid the demages comes from overheating.
Thank you in advance!
So my problem:
- I checked the T pipe and the hose to the head, it is clear
- The garden hose pressure shuld be enough
