I just bought a 96 waveblaster 2, 760. A couple questions. It does not want to idle even after being ran a long time. You have to keep your hand on the throttle to keep it from dying. But as long as you are hitting the gas it runs great. The guy I got it from says it needs new reed valves, does that sound right or would it be a carb issue? I pulled the plugs and they looked pretty old and were wet with oil, but that could be because I flooded it. however it was ran 10 minutes after that. If it is reed valves I need, are they hard to replace?
Also, any idea how much it might cost to get the carbs redone? I cant seem to find a "carb kit" for this thing....
