1991 Yamaha WR500 & 1991 Yamaha 650 Lx issues - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 5 (permalink) Old 06-04-2018, 09:03 PM Thread Starter
The 500 I can get running and it seems to run good, but if I shut it off I can't get it running again. It fires right up on the trailer as well, but in the water struggles a little initially.
The 650 will start on the trailer. Once in the water I can't get it to fire.
The were both filled up with marine grade mixed gas and had the plugs changed.
I did a compression test on both of them and took pics of the new plugs
500 I got readings of 130 & 115
650 I got readings of 120 & 10
In the pics the red stripe is the 500. Red, black and gray is the 650
What are some ideas what I should try?
ID:	16570   Click image for larger version
ID:	16578   Click image for larger version
ID:	16586   Click image for larger version
mikewohlwend is offline
post #2 of 5 (permalink) Old 06-05-2018, 06:47 AM
Compression is low. Should be in the 145 range and only a 10% variance max.
rodsatheart is online now
post #3 of 5 (permalink) Old 06-05-2018, 08:01 AM Thread Starter
Ok. So new pistons and rings? I'm more interested in fixing the 650 right now. Would I be better off looking for another motor or a rebuild kit?
post #4 of 5 (permalink) Old 06-05-2018, 08:34 AM Thread Starter
Also why will the 500 start on the trailer but struggle in the water? Battery?
post #5 of 5 (permalink) Old 06-06-2018, 06:28 AM
Low idle, low speed mixture screw not adjusted right, low compression.
Idle should be about 1100rpm out of water. Do not use the mixture screws on the side of the carb to set idle speed. The idle screw is on the throttle shaft.
Both engines need to be rebuilt.
Similar Threads
1991 Yamaha WR500 Fuel Line Locations mikewohlwend Yamaha Jetski 16 07-02-2018 06:17 AM
seadoo gti 720 throttle adjustment && rpm issues mccool3232 Sea-Doo Jetski 3 08-16-2016 06:37 AM
1991 wr500 fuel cap airwolf9090 Yamaha Jetski 0 05-13-2014 10:03 PM
1991 waverunner 650 lx HELP capstoneangler Yamaha Jetski 1 07-24-2011 10:31 PM
HELP!! '94 SL 650 & 750 dies at hard acc & turns skidoo Polaris Jetski 1 07-15-2010 10:02 PM
