wr500 fuel pressure - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 4 (permalink) Old 07-06-2009, 01:00 PM Thread Starter
wr500 fuel pressure
Hi. I am a PWC newbie, though I have 25+ years of boating experience. I recently purchased a non-running ’89 WR500, thinking I could get it going pretty easily, but it’s got me stumped. Sorry for the long-winded post, but here’s what I’ve done/learned so far…
I’ve narrowed the problem down to a fuel delivery issue. Compression is 125 PSI in both cylinders. I have visually verified there is strong spark, and it will start and run on starting fluid (which I have used very sparingly).
I rebuilt the round body Mikuni BN carburetor (new fuel pump diaphragms, etc…), and the pop-off pressure is about 9.5 PSI. However, even after the carb rebuild, there does not seem to be enough fuel pressure to force fuel past the needle/seat. I put a fuel pressure gauge on the fuel return outlet of the carb, and cranked the engine. I was only measured 3.5PSI. If I understand these carbs correctly, that is not enough fuel pressure to push fuel past the 9.5PSI pop-off pressure of the needle/seat.
There certainly seems to be significant “pulse” in the pulse line, though I’m not sure how to quantify whether it is “good” or not. I have also bypassed the fuel selector switch, and am pulling fuel directly from the reserve outlet on the tank. The tank does not seem to leak and holds pressure. The fuel flows freely (no restrictions) between the tank and carburetor.
I’m about ready to buy an SBN carburetor from atlanticjetsports.com, but wanted to ask if there’s anything I am overlooking? Is there a good way to verify that the “pulse” signal is strong enough? Does anyone know how much fuel pressure a good Mikuni BN carburetor should make? Is the SBN carburetor a direct bolt on swap for the existing BN carburetor?
Thanks in advance for your help!
butter is offline
post #2 of 4 (permalink) Old 08-02-2009, 09:00 PM
Will the machine start if you choke the carb manually by hand?
cranksho is offline
post #3 of 4 (permalink) Old 08-03-2009, 07:15 PM
Have you got the main fuel line and the return the wrong way around. Swap them and see what happens. Also, cut 10mm off the bottom of the feed sender in the tank to get the line off the bottom.
GCwaverunner is offline
post #4 of 4 (permalink) Old 08-03-2009, 09:47 PM
I believe the restrictor that gives you the fuel pressure is inside the carb. If I'm right, then measuring the fuel pressure in the return line isn't going to tell you anything since you are measuring after the restrictor.
John
1992 Polaris SL650 - Awaiting Repair
1990 Yamaha WR650LX
1994 Kawasaki 750SS
atc250r is offline
Similar Threads
Fuel pump pressure regulator?? Jgreenwood Kawasaki Jetski 2 05-26-2018 09:36 PM
Schrader valve adapter for fuel pressure gauge Frogman112 Sea-Doo Jetski 6 09-26-2017 05:52 PM
Need help finding a 05 GTX NA fuel pressure regulator jetkiller99 Sea-Doo Jetski 0 05-28-2013 10:44 AM
Pressure in fuel tank? Warnzie Yamaha Jetski 0 07-09-2010 12:48 AM
Compression pressure GP1200R -02 ??? Swedish Viking Yamaha Jetski 1 05-05-2008 05:40 PM
