07 vx check engine light, code 01 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 15 (permalink) Old 04-17-2018, 10:05 PM Thread Starter
Just had the 07 vx serviced with oil change and plugs. 120 hours on it. Ski runs fine as far as i can tell, but after maybe 30 minutes of riding, the check engine light turns on along with the warning light and buzzer. When i retrieve the code it says 01 which means that the system is running normal.
No other lights are on.
Can too much oil be the cause? What could it possibly be?
On a side note, about 2 weeks ago code 47 (slant detection switch malfunction) showed up but went away later without me doing work on it.
elefors is offline
post #2 of 15 (permalink) Old 04-21-2018, 08:01 AM
Have you checked the oil level after riding it easily for about 10 minutes to warm it up ?
rodsatheart is online now
post #3 of 15 (permalink) Old 04-21-2018, 12:25 PM Thread Starter
no i have not done that yet. when on my trailer the oil level is about halfway between full and empty on the dipstick. i cant say if the ski is sitting level or not, but based on what i've read, that seems to be too much when it's cold. that got me to thinking if too much oil can cause the check engine light to come on?
can a weak battery cause the light to come on?
i haven't had a chance to take it out on the water yet. maybe tomorrow?
elefors is offline
post #4 of 15 (permalink) Old 04-22-2018, 08:05 AM
Oil should be checked warm or hot. It expands. Yes a weak or bad battery can, and will cause the light to come on. How old is it ? To properly test it, it needs to be charged for about a hour on 1 or 2 amp, sit over night on the bench, then a load test done on it. If your noticing it seems to be cranking a little slower than normal, it is poss. the battery is on it's way out.
post #5 of 15 (permalink) Old 04-22-2018, 11:12 AM Thread Starter
i use a battery tender jr. to trickle charge it. i think its only half an amp. not strong enough?
elefors is offline
post #6 of 15 (permalink) Old 04-22-2018, 01:48 PM
Dave in DE's Avatar
The tenders are usually .5A to .75A they will charge the battery but will take longer depending on how low it is. With a tender leave it on over night.
How old is the battery?
Dave in DE is online now
post #7 of 15 (permalink) Old 04-22-2018, 06:13 PM Thread Starter
the tender indicates that it is fully charged. it does take longer than usual to start the motor. the battery does show a bit of weakness.
the battery came with the ski when i got it in march 2017. it looks new.
elefors is offline
post #8 of 15 (permalink) Old 04-22-2018, 09:30 PM
Dave in DE's Avatar
Unfortunately if you can't find a date on the battery there's no way to say how old. The batteries in a ski tend not to look old, as they are well protected. Don't want to tell you to get a battery as they aren't cheap. But you could charge it over night and take it to auto parts store for load test. And go from there.
post #9 of 15 (permalink) Old 04-26-2018, 06:24 AM Thread Starter
update: oil level is a wee bit above full after riding it around for 10 minutes like Rod said above. I will remove a bit of oil.
i have another ski so i swapped the batteries and the same jetski beeped the check engine light again while the other one with the "possibly bad battery" did not have the light come on. Pretty much rules out the battery?
What could possibly trigger the check engine light while still have the ski show code 01 and operate as normal?
elefors is offline
post #10 of 15 (permalink) Old 04-27-2018, 04:54 AM
The other prob. with the oil over full is it can find it's way into the intake system. Have you checked the voltage at the battery when it is running ?
Similar Threads
check engine light on VX SRB.FL Yamaha Jetski 2 05-03-2016 07:27 PM
2008 Yamaha VX 1100 Deluxe check engine light smw Yamaha Jetski 18 06-22-2014 07:19 PM
2008 VX check engine light and intermittent buzzer Franollie Yamaha Jetski 2 08-03-2010 10:39 PM
Check engine code retrieval question RSGAULT Polaris Jetski 0 08-14-2007 11:32 PM
Check engine light Hey Yu General PWC & Jetski Discussion 1 06-16-2007 12:06 AM
