Yamaha xl760 1998 hi low screw settings - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 4 (permalink) Old 03-30-2019, 05:24 PM Thread Starter
Hi all after a bit of advice hopefully you can help. I have a 1998 Yamaha xl760 has allways run fine till I stripped and rebuilt the carbs as have done many times before with no problems but this time I removed the high and low speed screws and set them to what the manual says but now when I ride it it runs fine mid range seems to struggle a little at the top end but if I go flat out then release the throttle and straight back onto it it seems to bog down any ideas please?
Jamie is offline
post #2 of 4 (permalink) Old 03-31-2019, 04:47 AM
Did you get the screws mixed up ? They are not the same. Did you reuse the needle spring and use a true Mikuni kit ? Did you get the regulator diaphragm installed correctly ? What are the setting you put the screws at ? You should always verify and document mixture screw settings before removing. Look at the plugs and see if it's running rich or lean. How easy does it start ? What happens if you go full throttle from idle ?
rodsatheart is online now
post #3 of 4 (permalink) Old 03-31-2019, 09:35 AM
vegasphotog's Avatar
Dang, Rod....you really know your stuff!
vegasphotog is offline
post #4 of 4 (permalink) Old 04-01-2019, 05:17 AM
I wouldn't get to carried away. lol
Similar Threads
Which screw is high adjustment/ low adjustment? Musto Yamaha Jetski 0 10-23-2012 12:07 PM
1998 xl760 yamaha/ not firing xl760 yamaha Yamaha Jetski 9 05-13-2012 01:16 AM
1998 Yamaha XL760 LCD Cluster scubaphil25 Yamaha Jetski 0 06-01-2011 01:12 PM
1998 xl760 always reading low fuel AlltheWaytoDMAX Yamaha Jetski 1 05-30-2011 08:19 AM
1998 Yamaha XL760 Cooling System captnosweat Yamaha Jetski 0 12-09-2010 07:26 PM
