2017 yamaha fxho rpm surging when wide open - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 3 (permalink) Old 04-06-2019, 08:30 PM Thread Starter
When running wide open, the rpm will surge from 6500 - 7800, but when I put in low rpm mode, it runs smooth wide open at about 6500 rpm's. Also if I set the cruise, it will run smooth up to about 6700 rpm's. Anyhting above that and it jumps around. Has anyone seen this problem? Any help would be much appreciated.
Have ruled out bad fuel and spark plugs
Thanks!
hfauch is offline
post #2 of 3 (permalink) Old 04-07-2019, 04:39 AM
Surging is normally a lean issue. It is caused by momentarily having enough fuel, then not having enough fuel. Could be water in the system, plugged filter, restricted supply line, bad pump, or bad tps.
Have you pulled the plugs to see how they're burning ?Check for any vacuum lines off or leaking. Did this start out of the blue, or after any modifications ? Might also have a load test done on the battery. A low amperage issue could be starving the pump and electrical system of necessary power.
rodsatheart is online now
post #3 of 3 (permalink) Old 04-07-2019, 04:51 PM Thread Starter
This started out of the blue but when I ran it today, it started running like it was running when I had an injector crack on me last year. feels like it is not hitting on all cylinders. thanks for the input!
hfauch is offline
Similar Threads
99 GSX rfi surging problem at wide open throttle Kyle Spatula Sea-Doo Jetski 5 04-06-2019 06:18 AM
1100zxi wide open mediceric Kawasaki Jetski 1 06-17-2012 12:53 AM
Throttle WIDE open!! ronqqq Yamaha Jetski 4 07-11-2011 03:21 PM
Polaris SLT 700- running wide open Troublemaker01 General PWC & Jetski Discussion 1 09-11-2010 11:42 AM
SL 750 Starts/Runs only wide open aclarc Polaris Jetski 5 09-05-2010 07:29 PM
