SBT Engines - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 16 (permalink) Old 04-30-2019, 02:14 PM Thread Starter
SBT Engines
Has anyone ever used an SBT Engine? Are they any good? Worth the Money? I'm thinking of replacing my engine in 1997 GP 1200.
gilberts is offline
post #2 of 16 (permalink) Old 04-30-2019, 05:59 PM
Dave in DE's Avatar
Definitely, DO NOT USE sbt! They are very poorly built. Missing and or wrong internal parts. Have heard nothing but horror stories over the years. I use there parts and gaskets due to cost but would never use a motor.
Where are you located?
There is pwcengines in NJ. depending on location, may have some local to you I may know of.
Pwc is cost wise about the same as sbt but I've heard good things of them.
What's wrong with your 1200?
Dave in DE is online now
post #3 of 16 (permalink) Old 04-30-2019, 06:05 PM Thread Starter
I'm in SoCal. The number 3 piston seized probably due to low oil intake. The sleeve probably needs to be replaced and I was told I should change the crankshaft. Number 1 and 2 are perfectly fine.
gilberts is offline
post #4 of 16 (permalink) Old 04-30-2019, 06:25 PM
Dave in DE's Avatar
Ok, cool, don't know of any in soCal. I'm know of a few on east coast. I'll do some asking around for you and post what I get.
Where at in SoCal?
Are you still out injected?
Do you have oil in you bildge?
Depending on how bad it may not need a crank.
If you have tool and mechanicly inclined 2strokes are easy build.
post #5 of 16 (permalink) Old 04-30-2019, 07:57 PM Thread Starter
The bilge had some oil but not a lot. I’m in San Diego.
gilberts is offline
post #6 of 16 (permalink) Old 04-30-2019, 09:04 PM
Dave in DE's Avatar
Ok. Oil in bildge is typical of oil line breaking/pulling off. So when you get into it. more than likely it's shrunk up and pulled off number 3 carb.
post #7 of 16 (permalink) Old 04-30-2019, 09:32 PM Thread Starter
It was still connected to the carb when I opened it up. I suspect it was clogged or something. So are you recommending a rebuild instead of a new engine? The sleeve also has a chip at the bottom.
gilberts is offline
post #8 of 16 (permalink) Old 05-01-2019, 05:09 AM
Let me ask around. I know of one up by Palmdale, but he is usually back logged.
rodsatheart is online now
post #9 of 16 (permalink) Old 05-01-2019, 06:31 AM
Dave in DE's Avatar
I
Yes, it can be rebuilt. So long as there are no open holes from a broken rod. If you just wiped a cyl a rebuild is what I'd do. The crank will need to be checked after a good clean up to be sure it's still in specs.
post #10 of 16 (permalink) Old 05-01-2019, 10:13 AM Thread Starter
Originally Posted by Dave in DE View Post
I
Thanks, that sounds like a better route to go since I can keep the original yamaha parts. Should I rebuild entire engine, new pistons, rings and bore out the cylinders? Also the sleeve in #3 has a chip at the bottom.
gilberts is offline
Similar Threads
To SBT, or not to SBT, that is the ? ZARDOZ General PWC & Jetski Discussion 8 04-05-2018 04:19 PM
SBT Engines? Worth it or no? nickg819 General PWC & Jetski Discussion 2 05-23-2013 08:09 PM
SBT engines gutter Yamaha Jetski 4 10-09-2009 09:31 PM
SBT Engines gutter General PWC & Jetski Discussion 1 09-27-2009 09:34 AM
sbt's honesty TxPro1200 Polaris Jetski 106 08-22-2006 09:01 PM
