Final problem with acquired 2001 XL800 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 15 (permalink) Old 07-22-2019, 01:39 PM Thread Starter
This is the last of 3 problems on this jet ski.
When starting with wide open throttle, it is just about to plane (about 15-17 MPH) when the motor suddenly revs up and acceleration stops. In order to accelerate past this point, I have to back off on the throttle and when it "catches" again I can gradually accelerate. Once past about 22 MPH, the throttle can be wide open with no issue. If I didn't know better, I would guess that it is cavitating causing the motor to rev and killing the acceleration. I have tried all settings of trim but that doesn't help the problem.
Anyone seen this or know what the cause/fix might be?
PickyBiker is offline
post #2 of 15 (permalink) Old 07-22-2019, 02:43 PM
Dave in DE's Avatar
You are correct it is cavitation. You'll need to check your clearance between the impeller and wear ring. Clearance should be .014"/.018". The max clearance is .024", but cavitation will be an issue if beyond .018". Impeller damage can also cause cavitation. It also could be an air leak around the pump shoe. (The part that bolts on behind the intake grate) they make a seal kit for it that fills all the air gaps in the shoe that help create the cavitation. Riva racing caries them I believe along with others. The shoe can be removed and sealed with a good silicone caulk. With the seal kit, caulk where green is indicated in the pics. Without seal kit, seal where red is. The shoe in pic has a seal kit installed. Just rubber plugs that fill the voids in the shoe. Can also be done with tubes of caulk.
If the impeller clearance is high and you still have the original stainless wear ring just replace the impeller. Then check clearance. Most times the rings don't need replacement. The Solas Concord are a good replacement Impeller. If it has an aftermarket plastic ring. Replace the wear ring insert also. Would suggest going back to original ring from plastic though as they create problems. And need frequent replacement.
Impro's is a good source for Impellers
Find a good used ring if needed on eBay or buy new at Babbittsonline.
Hope this helps, Dave
ID:	17717   Click image for larger version
Dave in DE is online now
post #3 of 15 (permalink) Old 07-22-2019, 06:43 PM Thread Starter
This machine sat unused for 14 years and only has 208 hours on it. I will assume for the moment that it is not impeller wear. It also had a ton of ants living inside the jet area. Your advice on sealing the shoe seems like a good and inexpensive first step. As always, I will let you know what happens.
post #4 of 15 (permalink) Old 07-22-2019, 07:22 PM
Dave in DE's Avatar
Yes, agree shoe is most likely culprit for air intrusion. Best to check clearance while grate and shoe are off. Will be very easy to get to them.
208hr can still be worn depending on riding conditions.
If you want I have a factory Impeller with 20hrs on it. Slightly lower pitch though. Shouldn't even notice it. Yours is listed at 13.4 pitch mine from an 02 gp800r is 13.2. give a bit more out of the hole and a tick lower top speed. But probably not even noticable. I'll let it go cheep. I'll never go back to it.
post #5 of 15 (permalink) Old 07-23-2019, 12:29 PM Thread Starter
I'll check the clearance and let you know. How cheap is cheap?
post #6 of 15 (permalink) Old 07-23-2019, 03:09 PM
Dave in DE's Avatar
How's the cost of shipping. I've got no way to measure it or guaranty it will tighten up your clearance. I only know the ski it came off is all original and a 22hr ski when I purchased it 2 yrs ago. It is very clean and no damage so it should be fine. Because of where I ride, and for reliability. I tore the whole ski down and resealed and upgraded some stuff and that included the Impeller. Otherwise it's all original/stock ski. I am at times 3 to 4 miles off shore. Didn't want to leave anything to chance.
post #7 of 15 (permalink) Old 07-25-2019, 01:36 PM Thread Starter
The clearance on the impeller looks like about .014 and the SS ring is spotless. Don't think that is an issue. There is no seal anywhere on the shoe an I'm guessing that's where the air is getting sucked in. I'm going to fill the shoe cavity with RTV and seal around the edges. Ill let you know if that fixes the cavitation.
post #8 of 15 (permalink) Old 07-26-2019, 05:25 AM
Dave in DE's Avatar
Clearance is good. So sealing the shoe should do it. There's a foam seal along the back edge that falls out/goes bad and breaks the seal. This allows air in from the ride plate area.
I'll test my gpr's draw this weekend to see if and how much the meter draws. Just for shits and giggles.
post #9 of 15 (permalink) Old 07-26-2019, 10:14 AM Thread Starter
Yes, the foam seal at the bottom is brittle and chunks are missing. I scraped it off and will replace it with a 3D printed seal made of TPU. TPU is a rubbery type material and I will add RTV to both sides as well. I have the shoe pockets filled with RTV now and I will put more around the edges when I reinstall it. That should take care of any air leaks.
post #10 of 15 (permalink) Old 07-31-2019, 09:59 PM
ZARDOZ's Avatar
Once again, try these two things before you go hog wild.
1. Install an aftermarket Aquavein intake grate.
2. Stuff the pump shoe housing with a pump shoe housing stuff kit.
You can do these two things yourself, and you will need the grate, the kit and some 3M sealer. I did this to my 2001 XLT 1200 which was exhibiting the same characteristics that you describe, and the problem was rectified. A heck of a lot easier than messing with the impeller.
I, of course, eventually changed the impeller but that had more to do with speed than with cavitation. costs were about $100 for the intake grate, $80 for the shoe stuffing and $15 for the 3M marine sealer.
Give it a try before you mess with the impeller. It may save you a lot of time and headache.
Zardoz
ZARDOZ is offline
