1993 Yamaha vxr pro starting problems - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 9 (permalink) Old 07-30-2019, 08:02 PM Thread Starter
Hey guys I need some help with my vxr pro. I went out riding today, and after turning it on and off throughout the day with no problems, I went to start it again and all I heard was a single click with each press of the start button. I thought maybe the battery had somehow died but I checked and it was at 12.7 volts, and it isn’t the starter or solenoid as I replaced those two weeks ago. Any help would be amazing as I am clueless at the moment.
jharri7140 is offline
post #2 of 9 (permalink) Old 07-30-2019, 10:29 PM
Dave in DE's Avatar
Sounds to me to be the solenoid. Check at starter with volt meter when you press start button. See if you get voltage. If no it's solenoid. If yes it's starter. Could also be a loose cable being you just replaced both.
Dave in DE is online now
post #3 of 9 (permalink) Old 07-31-2019, 05:29 AM
Check the voltage when you press the starter button.
rodsatheart is online now
post #4 of 9 (permalink) Old 07-31-2019, 11:58 AM Thread Starter
I checked the solenoid and it was only putting out 6.3 volts so it seems to be the issue, but I don't want to buy a new one just to go and blow it up and start this process again, any idea why a brand new solenoid would break on the first day of use?
post #5 of 9 (permalink) Old 07-31-2019, 11:55 PM
Dave in DE's Avatar
Where did you get it from? When it comes to electrical parts I'll only use genuine Yamaha parts. The cheep aftermarket ones just won't hold up. Order from Babbittsonline.
post #6 of 9 (permalink) Old 08-01-2019, 12:11 AM
Dave in DE's Avatar
I have 2 vxr pro's. A 93 & 94. They are a blast to ride.
If you PM me your email address I can send you a pfd file of the factory shop manual for the vxr pro.
post #7 of 9 (permalink) Old 08-01-2019, 04:51 AM
What is the voltage at the battery when you press the start button ? Be sure and check that all grounds are tight and clean.
post #8 of 9 (permalink) Old 08-01-2019, 04:19 PM Thread Starter
Solenoid came from DB electrical, I have used them before in the past and haven't had any issues until now. I will make sure to check that the ground is good. Thanks for the help
post #9 of 9 (permalink) Old 08-03-2019, 05:01 AM
Just a thought, have you checked that you can turn the engine over by hand with the plugs out to make sure something is not locked up ? Might look in the jet pump to make sure something isn't wedged in there also.
