2001 xlt only doing 7 mph - Page 2 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #11 of 21 (permalink) Old 08-17-2019, 08:38 PM Thread Starter
so just got home with the ski, did a compression test on it, cold, with just the one spark plug out at a time. and WOT- Front was 112, middle 115, rear was at 112. not bad for cold?
Last edited by Faron V; 08-17-2019 at 09:21 PM. Reason: forget to do WOT while testing, also made sure I had tester snugged down all the way
Faron V is offline
post #12 of 21 (permalink) Old 08-22-2019, 10:35 PM Thread Starter
do these clips look to small to fit my power valve? trying to put the second one on it snapped the one side off. they are supposed to be for a 1200 xlt, yet seem really narrow.
ID:	17909   Click image for larger version
ID:	17911   Click image for larger version
Faron V is offline
post #13 of 21 (permalink) Old 09-13-2019, 01:07 AM Thread Starter
Hey all, just an update. Finally got all my parts, and rebuilt the carbs, did the fuel rail mod, Followed OsideBills recipe for the carbs.including FA's, I also removed the cam from the accelerator pump, but i added a steel cable to the arm of the accelerator pump and ran it up and through the vent under the back corner of the seat, so i can grab that cable and give it a couple of pulls to prime. worked well, then I Managed to swear a lot and get it all back together last weekend and took it out for a test. Prime cable worker great. Ski ran like it should, or better!! the water was quite choppy but had it up to 44 Mph quite easily with lots of throttle still. I am hoping to get it back on water this weekend and see what she can do! The season up here in Western Canada wont last much longer, So gotta have fun while we can! Thanks for the help and lets hope all will keep running well.
Faron V is offline
post #14 of 21 (permalink) Old 09-13-2019, 06:07 AM
Good deal.
rodsatheart is offline
post #15 of 21 (permalink) Old 09-13-2019, 07:19 AM
Dave in DE's Avatar
Glad to here good out come. Ride safe and have fun.
Dave in DE is online now
post #16 of 21 (permalink) Old 09-16-2019, 12:51 AM Thread Starter
ok, so another update. I had awesome weather this weekend, had the ski in several times. It worked well hitting a max of 53 on the speedo, as fast as I need to go anyway. however the last while this afternoon, when cruising it would seem to bog down a bit, even cruising at WOT, it would change sound, and drop to about 29 MPH, and the revs would go no higher then maybe 5000. it did it a bit, then seemed to be getting worse, doing it more and more. if i stopped the ski and then hit the throttle ,no problem for a bit, or if it was doing it a lot, I could stop, shut it off. then restart and it it would take off like it should. Fuel was getting a bit low, and on the way back in it stalled, i switched to the reserve , started and it seemed okay. i didnt ride more then 2 minutes after that and was heading to the launch. Just thought I would ask if any ideas, or was i just getting that low on fuel that it would cause that bog. any thoughts or insight would be much appreciated! :-)
Faron V is offline
post #17 of 21 (permalink) Old 09-16-2019, 05:49 AM
Prob just low on fuel, which is actually dangerous on a 2 stroke because your running it lean.
post #18 of 21 (permalink) Old 09-16-2019, 08:27 AM
Dave in DE's Avatar
I concur with Rods, sounds like you were starving for fuel.
post #19 of 21 (permalink) Old 09-16-2019, 09:29 PM Thread Starter
okay will keep a better eye on it, it went through the tank pretty fast! live and learn. Thank you.
Faron V is offline
post #20 of 21 (permalink) Old 09-16-2019, 10:37 PM
Dave in DE's Avatar
Ya, they consume several "gallons" per hr. A tank is only good for a couple hours of high speed run time.
