2000 Yamaha 1200 XL Limited - Page 3 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #21 of 35 (permalink) Old 09-26-2019, 08:03 PM
Dave in DE's Avatar
Originally Posted by Peteysparks View Post
🤦‍♂️ Need to learn proper quote procedures lol
To do a quote: tap the little square in the upper right corner of the post you want to quote. Then tap the quote mark on the green bar beside the BLK circle you use to post. And Wa,la, your there.
Dave in DE is offline
post #22 of 35 (permalink) Old 09-26-2019, 08:19 PM
Dave in DE's Avatar
[/QUOTE]
What’s the packing made out of? What should I have on hand?
This will be another task for winter. There’s only 96 hours on the original motor. I’ll for sure let you know what I find. Thanks again Dave![/QUOTE]
I disconnected the fill hose and sending unit wires. Put a mess of paper towels in the floor of the ski. Unbolted tank straps, an appsolute 'PITA'. Then took loose the hose going to the pump and removed with finger over hose connection on tank.
You probably will need to remove the exhaust From the rubber coupling on back to get room.
Tie the hose to the pump up so it doesn't drain everything out of the pump or plug the line.
The packing is a donut made of some kind of foam rubber. To seal the end of the filter and tank connection.
You may be surprised what you find. But then again it may not be to bad other the paraffin. Although my 02 gpr only had 30hrs on it a couple yrs back when I bought it. And it had a mess in it. My 01 had a hand full of sand in it. It was a beach ski so they weren't very careful filling it. But then again they never flushed either. Motor was a corroded mess in cooling jackets.
post #23 of 35 (permalink) Old 10-08-2019, 11:20 AM Thread Starter
Peteysparks's Avatar
Any ideas to fix the following issue that I think is carburetor or fuel delivery related. My wave runner is breaking in well except I need to slightly choke the carbs to get speeds higher than 10mph. If I increase throttle while the choke is fully in (open) it boggs down and sounds like it’s going to die out. Only after choking a little does it take off to a good speed upwards of 50 mph. It’s never died and seems to idle well. Occasionally I’m hearing it miss but that could be because the plugs are oil fouled. I had the break in oil mixed in the gas for the first 10 gallons. I added a fresh 4 gallons or so this last weekend. I’d say there was about 4-5 gallons left in the tank so there’s still a oil mix. I did change the plugs but still no change with the carb issue. Any suggestions?
Peteysparks is offline
post #24 of 35 (permalink) Old 10-10-2019, 11:45 PM
Dave in DE's Avatar
If you need to add choke to run your to lean on carbs. Your running a risk of lean seizure. Best bet is to give the carbs a full rebuild with Mikuni kits.
post #25 of 35 (permalink) Old 10-14-2019, 04:04 PM
Hello.....
I Also have a 1999 XL1200 Ski here in the UK. I was told that these engines are pretty good as they don't have the reed valves fitted which break up and lunch the engine....Apparently the reed valves were fitted to the XLT1200.....Does anybody know if my information is correct?
spannerman is offline
post #26 of 35 (permalink) Old 10-14-2019, 09:58 PM
Dave in DE's Avatar
Originally Posted by spannerman View Post
Hello.....
w
Hi Keith,
The 99 does have Reed valves. But may not have power valves in the exhaust. listings for US models show that the 99 had power valves and the 98 did NOT. But that may not be the case with UK models. Easy way to tell. On the left top of the motor there will be 3 little four bolt covers. If it has power valves. there at an angle and partly covered by the exhaust manifold. See pic.2000 Yamaha 1200 XL Limited-img_20191014_215447_1571104646844.jpgClick image for larger version
ID:	18049Click image for larger version
post #27 of 35 (permalink) Old 11-03-2019, 01:54 PM Thread Starter
Originally Posted by Dave in DE View Post
At this point I'd leave it till after riding season. Do it as an off season repair. If it won't come out gripping the insert with vise grips. Then you may need to drill a Small hole in the top of the insert to spray in some pb blaster. Let it soak a day or two. Then try with vice grips again. Once out you'll need an 8mm tap to clean up the insert threads. Clean the outside of the insert and epoxy real good with acetone. Rough it up with sand paper and clean again. Then mix up plenty of jb weld and reglue the insert with plenty of jb weld. Then use anti seise on your bolts.
Since the season is over I went ahead and drilled small holes and let penetrating oil do it’s thing. I got one out, one snapped off and the other two are just spinning. Not sure if it’s my vice grips but that doesn’t seem to work. Even tried a little torch on the bolts. I’m getting a good clamp on the brass inserts but it’s difficult to contort your arms in into the hull. I’m sure some of you know what I mean. So it’s looking like I’m going to have a good size repair for the winter. I’ve read some advice on how to remove the epoxy inside the hull and so forth. First is to get the bolts removed. Maybe I need to really heat up the bolts but I don’t want to damage the hull. Any advice? Thanks.
post #28 of 35 (permalink) Old 11-04-2019, 12:00 AM
Dave in DE's Avatar
Sense you've already broken one and others are siesed. You may want to replace the brass inserts with one piece ones. I believe the ones used on the 04 and up GP1300r will work based on my findings. (Babbittsonline part number F1G-U8571-02-00). This will require some work to prep and glue/epoxy in, but would be a permanent repair. If you go this route clean area well with acetone before and after sanding.
Check out this sticky on Greenhulk pwc forum. It's in Yamaha, how to's (see pic). this is a pump tunnel reinforcement sticky but uses the one piece plates to replace inserts.
post #29 of 35 (permalink) Old 11-04-2019, 06:43 AM Thread Starter
Thank You! After I remove all the epoxy that’s holding in the inserts, will they just come out? It seems they’re held in somehow. I see how the bracket will work if the bolt spread is the same dimension. What kind of epoxy should I get? Is it the west marine? I’m guessing some 5200 will hold it in place once I get the alignment right with the shoe bracket. Then epoxy them in from the hull. For what the bracket costs it’s worth a try to just order since I have lots of work to do.
post #30 of 35 (permalink) Old 11-04-2019, 06:51 AM Thread Starter
Looks like I need part 59 see attached
