First PWC waverunnerIII 700AV - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 11 (permalink) Old 09-21-2019, 05:17 PM Thread Starter
WRA700AV
Hey Hey just picked up a waverunner from a guy because hes moving he let it go, with trailer, for ahundred bucks. Pretty sweet deal but the jetski needs....some TLC.
I dont know where to start with it. It sat awhile so i guess ill dump the fueltank, change the fuel filter, hook up the hose and fire er up.
Any tips too look for would be great or info and specs about Im having trouble finding info on this specific model i dont even know the year but i guess 95-97.
Thanks! Happy to be here this forum seems great
ID:	18005   Click image for larger version
ID:	18007   Click image for larger version
Jet Jet is offline
post #2 of 11 (permalink) Old 09-21-2019, 05:25 PM
Dave in DE's Avatar
Looks to be a 93/94. Easy way to tell. The second pic of the rear I can see the HIN tag on that rear step. The last 2 digits are the year.
Dave in DE is offline
post #3 of 11 (permalink) Old 09-21-2019, 05:33 PM Thread Starter
Thanks dave if thats the case it seems to read xxxx1990
What do you think of these make/model?
Jet Jet is offline
post #4 of 11 (permalink) Old 09-21-2019, 05:35 PM Thread Starter
Engine says J700C 62G 02174
Jet Jet is offline
post #5 of 11 (permalink) Old 09-21-2019, 09:05 PM
Dave in DE's Avatar
Jet,
I have 2 very similar ski's. A 93/94 vxr pro w/701 motor. They are very fun beginner ski fun to ride and do flat spins on. They have a flat bottom so spinning them is pretty easy once you get the hang of it. Mine do about 40 mph with pretty much stock motor and blueprinted pump and solas Impeller.
Part are easy to find on eBay or at Babbittsonline and partzilla.
post #6 of 11 (permalink) Old 09-22-2019, 08:12 AM
Put a couple of table spoons of 2 stroke oil in the cyl's to coat everything. Carb rebuild, compression test, and oil injection lines should be first and foremost on the list.
rodsatheart is offline
post #7 of 11 (permalink) Old 09-22-2019, 11:25 AM
Dave in DE's Avatar
Rods is on top of it for where to start. After cleaning fuel tank. I would also recommend turning it over by hand from the rear coupling a few times before trying with the starter. Easiest to do with plugs out of coarse.
post #8 of 11 (permalink) Old 09-23-2019, 02:54 PM Thread Starter
should i start a new thread for this?
the oil tank was removed i assume they've just been running mix in the gas tank so no oil injection lines. i would like to go back to that it seems like less of a hassle than premixing myself.
the plugs are new and then engine itself looks good and turns over easily by hand with plugs out. i put a small amount of oil in the plug holes.
i have the battery on a charger i may need to replace, tho, it seems to be charging.
havent touched the carb.
Is there a way to separate the hull from the top to make all this more accesible? it looks like the bumber screws hold it together but idk if its sealed all the way around as well.
Jet Jet is offline
post #9 of 11 (permalink) Old 09-23-2019, 08:17 PM
Dave in DE's Avatar
Ya take it over to Yamaha thread.
No way to separate the upper/lower half. Correction it is possible but truly there epoxied together and very difficult to separate and not recommend.
The oil injection does make life easier. But without all the parts it will be expensive to replace everything. You may able to piece meal it in used parts off eBay. That would save some over new parts
post #10 of 11 (permalink) Old 09-24-2019, 04:33 AM
I'll just move this one.
