Hi,
i have some interesting issue,
my jet have hard start, like have to crank it few times to start,
then i go full speed, no problem with the jet every thing ok speed, performance.
However when i go slow or idle the engine cuts off.
power still on, just the engine goes off.
then again, takes time to start
Note sure what is happening...
I had few weeks back beeping indicator and notice that the battery was not charging, however i spray the voltage regulator connection with contact cleaner, and the error disappear
battery is charging.
any suggestions? thank you
